Separate Outputs?
Greetings.  I had a Variax some years ago but, for reasons I won't go into here, had to sell it.  Therefore, I'm considering getting another one.  I am something of an experimental guitarist and was wondering about a couple of things regarding the JT Variax guitars.
First, are the outputs separate for the mag pickups and the models?  If not, can they be?  I am interested in trying some ideas involving standard tuning simultaneously with altered tuning through separate amps/effects.
Secondly, is it possible to add a Sustainiac pickup to a JT Variax?
Any info would be greatly appreciated.
Thanks very much.
Ron
The outputs can be separated by using the VDI output with a compatible Pod HD device (HD Pro/x, HD500/x). These devices can recognize both inputs separately and simultaneously as Inputs for dual-path DSP.
The outputs cannot be processed separately and simultaneously using the 1/4" JTV jack, nor when using the VDI connection with earlier VDI-enabled Pod processors (Pod xt Live/Pro and Pod X3 Live/Pro).
Silverhead and Charlie Watt:  thank you very much for the responses regarding the mulitple outputs issues.  Very helpful.
Is there information anywhere regarding my other question - installing a Sustainiac into a JT Variax?
Thanks again.
Ron
