damien76 Posted January 3, 2014 Share Posted January 3, 2014 THis is the first time I am using Line6 products. I got a vetta2 + fbv longboard (both 2nd hand). It was really fun meddling with thousand and thousands of settings. However, I noticed that when i change channel, there is an obvious lag. Can anyone advise me whether this is normal? I tried to google and did a reset of the floorboard. The same lag still happens. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 3, 2014 Share Posted January 3, 2014 There is a slight audio gap when changing presets on the Vetta. It doesn't have anything to do with the foot controller. It's just that when you switch presets, you're essentially telling the processor to stop doing one thing and start doing another. So there's a slight gap. If it bothers you a lot, you can compensate by putting a delay pedal in the effects loop. Quote Link to comment Share on other sites More sharing options...
damien76 Posted January 12, 2014 Author Share Posted January 12, 2014 Thanks Phil. That means I cannot use the longboard for "live" playing unless I am using just a single preset/channel Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 13, 2014 Share Posted January 13, 2014 That means I cannot use the longboard for "live" playing unless I am using just a single preset/channel Well, you have to do whatever you're comfortable with. Lots of guys have used the Vettas live over the years with the longboard, so I'd say it's not impossible. I think you just need to time your preset changes accordingly. Quote Link to comment Share on other sites More sharing options...
