itsdavidthegreat Posted July 4, 2019 Share Posted July 4, 2019 I have an HD500X now, and the FX loop block always consumes one of the footswitch slots - is this true in Helix also? Also, say I wanted to use the Helix for vocal effects processing also... could effects units be in the signal chain, but controlled via MIDI instead of footswitches? Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted July 4, 2019 Share Posted July 4, 2019 1 hour ago, itsdavidthegreat said: I have an HD500X now, and the FX loop block always consumes one of the footswitch slots - is this true in Helix also? Also, say I wanted to use the Helix for vocal effects processing also... could effects units be in the signal chain, but controlled via MIDI instead of footswitches? Helix CAN have an FX slot. It doesn't have to. Considering it can max out at 32 blocks if you have enough DSP, you'll be fine. Also, yes, it accepts midi control. Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 4, 2019 Share Posted July 4, 2019 2 hours ago, itsdavidthegreat said: I have an HD500X now, and the FX loop block always consumes one of the footswitch slots - is this true in Helix also? The wording "footswitch slots" is misleading.... I think you mean "effects blocks". Yes, the FX loops require the use of an effects block, but with the Helix you get 32 of them compared to 8 (+amps) on the HD500 so it's not nearly as limiting. If you actually mean "footswitch".... neither unit forces you to tie the FX Loop to a footswitch - that's up to you. Quote Link to comment Share on other sites More sharing options...
itsdavidthegreat Posted July 5, 2019 Author Share Posted July 5, 2019 On 7/4/2019 at 5:45 PM, codamedia said: The wording "footswitch slots" is misleading.... I think you mean "effects blocks". Yes, the FX loops require the use of an effects block, but with the Helix you get 32 of them compared to 8 (+amps) on the HD500 so it's not nearly as limiting. If you actually mean "footswitch".... neither unit forces you to tie the FX Loop to a footswitch - that's up to you. Oh interesting, I thought of the effects blocks in the HD500x HAD to be assigned to one of the 8 footswitches. I guess with the 500x you might as well assign it to a FS since you only get 8? Either way, 32 on Helix sounds amazing Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 6, 2019 Share Posted July 6, 2019 13 hours ago, itsdavidthegreat said: Oh interesting, I thought of the effects blocks in the HD500x HAD to be assigned to one of the 8 footswitches. I guess with the 500x you might as well assign it to a FS since you only get 8? I guess if you run the HD500 in 8 FS mode... I always ran man in 4/4 mode (4 patch/4 effects). In that case I would never assign an "always on" block to a switch. Quote Link to comment Share on other sites More sharing options...
