browsell Posted July 13, 2019 Share Posted July 13, 2019 Hi I have a firefox FX and it won't power on. There is a very dull blue light on the display but nothing else. Help!! Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 13, 2019 Share Posted July 13, 2019 I suggest you open a support ticket. https://line6.com/support/tickets/add.html Quote Link to comment Share on other sites More sharing options...
browsell Posted July 14, 2019 Author Share Posted July 14, 2019 Thanks, I have created a ticket and hope to get some help. Cheers Quote Link to comment Share on other sites More sharing options...
browsell Posted July 17, 2019 Author Share Posted July 17, 2019 Hi I wrote a ticket and was passed on to Yorkville in Canada to make inquires. Have left messages for 3 days with no response. Is there anyone at your end that can give some advice on why I'm just getting a dull blue light when I power on unit. I was considering buying the Firefox 1500 watt amp but not sure now! Thanks Bill Quote Link to comment Share on other sites More sharing options...
browsell Posted July 17, 2019 Author Share Posted July 17, 2019 This is all I'm seeing with the back cover off. Blue display on front is very dull with vertical lines where the info should be displayed. Quote Link to comment Share on other sites More sharing options...
browsell Posted July 17, 2019 Author Share Posted July 17, 2019 When I push down control knob+FS2+FS3 at the same time and hit the power on switch I get a solid red light on the "A" foot switch? Quote Link to comment Share on other sites More sharing options...
Lukeb90 Posted September 21, 2021 Share Posted September 21, 2021 This is the exact same thing that is happening to me… Have you figured out the issue?? Quote Link to comment Share on other sites More sharing options...
NucleusPrime Posted October 21, 2021 Share Posted October 21, 2021 This sounds like a damaged, loose, or dirty internal SD card. You can try removing the SD card cleaning it and then reinserting it. This has worked for people in the past. If that doesn't work you could try a replacement SD card. You'll need to get one specially for the Firehawk FX from a Line6 parts supplier because there is no way to flash the firmware to the SD with it in the unit and I'm not aware of any PC software that can write the firmware to it directly. Quote Link to comment Share on other sites More sharing options...
