nigni83 Posted July 14, 2019 Share Posted July 14, 2019 Hello! I d Like ti replicate the sound of my fender HRD drive using hx effects, wich setup/distortion would you suggest? Thanks Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 14, 2019 Share Posted July 14, 2019 Are you plugging the HX Effects into the clean channel of the HRD? If so... I'd suggest the Tee-mah (Timmy). It will add a touch of thickness/edge to the tone and you can vary the amount of overdrive. If you are using another amp, we likely need to know the setup before making a suggestion. Quote Link to comment Share on other sites More sharing options...
nigni83 Posted July 14, 2019 Author Share Posted July 14, 2019 Yes i m using that amp, but my idea Is trying to replicate that sound using the hx direct in the PA in a live gig, i d add and ir and the teemah..do u suggest other effects for Better simulation? Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 14, 2019 Share Posted July 14, 2019 If you are actually wanting to dump the amp and just run the HX Effects into the FOH, it's not that easy since the HX Effects doesn't have amp simulation. You need a Helix or HX Stomp for that. If you are still running your amp on stage for yourself, then for simplicity sake I would run it like this.... Guitar > HX Effects (load effects just like a pedal board here) > Load a LOOP block on the HX > HX Send 1 to Amp Input > Amp Send to HX Return 1 > Load IR in the HX > HX Output to Direct Box / FOH This gives you a pedal board of effects prior to the amp (like a standard pedal board would be), the amp will still create sound for you and send it's preamp tone to the HX return, the IR will provide the speaker sim for the FOH. No more simulation needed.... it's your effects with your amp. The only difference is YOU hear the speaker on the amp, the FOH gets the IR. You can get more complicated with a 4 cable method (one more return to the amp) but then you need a 2nd SEND block on the HX or a split of the left right output and the IR on a separate path to keep the IR away from the amp. It's all up to your comfort zone with routing. Quote Link to comment Share on other sites More sharing options...
nigni83 Posted July 14, 2019 Author Share Posted July 14, 2019 Wow thanks dude! That s what i was looking for! I ll try It for sure! Thanks a lot!!!! Quote Link to comment Share on other sites More sharing options...
nigni83 Posted August 17, 2019 Author Share Posted August 17, 2019 Dear friend, i spent lot times trying to set up a preset in 4cm with an ir on the send2 with no results .. i cant do that, would you be so nice ti send me a preset or Just a draw of the chain? I can use the send2 with a ir as earmonitor only in normal setup, not 4cm Quote Link to comment Share on other sites More sharing options...
