refagaem Posted July 17, 2019 Share Posted July 17, 2019 Hi , i just receive an HX stomp, and i'd like to integrate it in my PBC Mastermind in Pre mono and Post stereo , is there someone who tried this? Thanks Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 17, 2019 Share Posted July 17, 2019 To clarify, you are looking to setup a mono chain for one loop in the PCB, and then a Stereo chain for a second loop? That wouldn't be difficult, but it will require one of the following in the Stomp A mono send block & a stereo return block (consuming two of six blocks) or A stereo loop block (this is what I would use to converse blocks) In option two you chain could be as follows.... PCB Send > Stomp Input > insert mono effects > Stomp Loop 1 Send > PCB Return PCB Stereo Send > Stomp Loop 1/2 Return > insert stereo effects blocks > Stomp L/R Output > PCB Stereo Return If I have misunderstood what you are looking to do, please disregard :) Quote Link to comment Share on other sites More sharing options...
refagaem Posted July 18, 2019 Author Share Posted July 18, 2019 Many thanks for your input! l'll do my best to understand the path notions in the stomp, in fact i would like to use one preamp loop of PBC (mono ) before the input of my amp ( Victory V 40 Deluxe) for mod, disto, an others mono effects.. and if it's possible using a stereo loop of PBC in parallel, to delay, reverb with kill dry engaged, one path return to amp, the other to mixing desk I don't know if i'm clear, my english is very limited Thanks again! Hervé Quote Link to comment Share on other sites More sharing options...
