HX Stomp Noisy Footswitches
jvc123
Just now, jvc123 said:
Its extremely odd. If I touch a switch with my finger it is noisy. If I cover the switch with a duster and touch it it's not!!
What do you mean by "duster" here?
Do you have the Blackstar and the Stomp plugged into the same outlet/power strip?
2 minutes ago, jvc123 said:
Duster is a cloth.. Separate outlets
Try plugging them in to the same outlet if possible.
This is probably related to the capacitive touch feature. It seems like it's a ground loop of some sort, but there might be way to minimize it. Do you hear the noise with headphones?
43 minutes ago, jvc123 said:
I'm afraid I don't use headphones. I will try the same outlet.
Well do you have headphone that you could at least try? I think it's worth seeing if it's something unique with the amp or something with the Stomp itself...
You could also try going to Global Settings>Footswitches and turning the Stomp Select parameter to "Press". That will turn off the capacitive touch feature.
