ericmb Posted July 28, 2019 Share Posted July 28, 2019 hi all, I ve got a helix hx I am trying to use for channel swap on the amp. For all of the above the following applies: - JVM footcontroller is disconnected - JVM midi is on MIDI channel 1 - MIDI operation Pressing the FOOTCONTROLLER / MIDI PROGRAM switch twice puts the amplifier in MIDI waiting mode, the LED will flash until a valid MIDI program change command is received Boss ES5 (works) I can get it working using a Boss ES5: https://www.youtube.com/watch?v=3YI65cgA4XI Midi cable setup: Boss ES5 (out) > JVM (IN) Also going from Boss through the helix (midi passthrough works). Midi cable connection: Boss ES 5 (out) > Helix (IN) > Helix (out) > JVM However, this is using Midi patch panel change. Not sure how this differs from MIDI CC? Helix HX (not working) For Helix im following this video : https://youtu.be/simaPS7dzLw?t=55 Midi cable connection: Helix (out) > JVM I am using MIDI CC and following the table in JSH User manual. channel : 1 Function: CC: 16 value 2 = clean channel, Orange mode. I set the amp up so that the midi controller is BLINKING and it doesnt stop blinking: its not receiving the signal? I feel like Im close to getting there. Any ideas? Thanks, Eric Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 28, 2019 Share Posted July 28, 2019 Starting with the assumption that BOTH the Helix and Amp are set to MIDI Channel 1. From a quick look at the manual, this: - MIDI operation Pressing the FOOTCONTROLLER / MIDI PROGRAM switch twice puts the amplifier in MIDI waiting mode, the LED will flash until a valid MIDI program change command is received Sets the amp to receive a MIDI Program Change message, and isn't necessary for Channel changes. Setting a Helix switch (or Instant Command) to send a CC# (16-17-18-19) with a Value (0-1-2) SHOULD change the channel and mode. Quote Link to comment Share on other sites More sharing options...
