Guest Posted July 28, 2019 Share Posted July 28, 2019 Hi, before I' m going to update my Helix to 2.80, I would ask someone of the most "guru" of this forum, if now , with the modified features in " Command Center " it' s possible to change channels in amps as Marshall Vintage Modern or YJM which use a "relay" and not a regular "switch". If not, I probably stay with 2.71....no need other update 'cause I use Helix most as "ambient effects" in 4 cable method. And the 2.80 hasn't new modulation or ambient effects….. Thank you! Quote Link to comment Share on other sites More sharing options...
Sipuri Posted July 28, 2019 Share Posted July 28, 2019 Having an issue with 2.80 for the HX Stomp. External FS4 (function loaded with Bank Up, or any other function) without function, whereas FS5 (function loaded with Bank Up, or any other function) working fine. Tried 2 different external FS, same issue with both. Anybody with the same issue arround? Greez from Germany, Stefan Edit: I did a roll back toV 2.71 and everything is working fine again. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2019 Share Posted July 28, 2019 …..anyone?...…. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 28, 2019 Share Posted July 28, 2019 7 hours ago, viola said: …..anyone?...…. You waited all of 5 hours between posts...you didn't hear anything because the answer is very amp-specific. You'll have to wait around for someone to stumble upon this thread who has both already updated to 2.8, and who also just happens to own the same (or similar) amp... you can't realistically expect an instantaneous response to this one. It'll be a hell of a lot faster to just do the update, and see if it works. You'll have your answer inside of 20 minutes. Worst case scenario, you roll back to 2.71. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2019 Share Posted July 29, 2019 I agree with you cruisinon2... It' s faster do myself the update and check it than waiting for the answer !!! But after a careful reading of new features in 2.80 update, I have noticed that the only modification in the "Amp Switch" via Command Center is the add of a "momentary" latch in the switch that remains a "mechanical" switch (on/off), while to open/close relays is needed an "electronic" switch…. My english is bad..I guess you'll understand….! Quote Link to comment Share on other sites More sharing options...
Sipuri Posted July 29, 2019 Share Posted July 29, 2019 Problem solved. Update overwrites the Global Setting/Preferences. That's where the Exp/Tip Exp/Ring settings have to be aligned to FS4, FS5 first, before loading FS4 FS5 in the Footswitches setting with desired function. No bug, V2.80 working fine now. Greez from Germany, Stefan Quote Link to comment Share on other sites More sharing options...
