anthdidj Posted August 5, 2019 Share Posted August 5, 2019 I am running Pro Tools 12 and have set the playback engine to 'HX Stomp'. Following the manual for reamping a DI track... I set the input on the helix to usb 1/2 and then I go to set up the output of the DI track to USB 5/6 however I do not see this as an option. I assume my I/O is not setup correctly? The in's work fine and I have recorded with the Helix into Pro tools which it automatically setup for me but doesn't seem to have assigned the outputs. How do I go about doing this? Quote Link to comment Share on other sites More sharing options...
zolko60 Posted August 5, 2019 Share Posted August 5, 2019 What do you see in "I/O Setup"? Did you try to reset to "Default"? Quote Link to comment Share on other sites More sharing options...
anthdidj Posted August 6, 2019 Author Share Posted August 6, 2019 Awesome that fixed the problem thank you. One more question... I only want to record in mono so do I set the output of the DI to out5 and reamp track to in1 or do I have to keep the output of the DI to out 5/6 (stereo) and just change the reamp track to in 1 (stereo out to mono in record?). Doesn't seem to change the sound of the re-amped track either way. Quote Link to comment Share on other sites More sharing options...
zolko60 Posted August 6, 2019 Share Posted August 6, 2019 If it doesn't change anything I would not bother. ;) Quote Link to comment Share on other sites More sharing options...
