Blubarb Posted January 10, 2014 Share Posted January 10, 2014 Hi all I seem to have quite a hiss when I turn up the Master dial to about the third dot and more. Is there a way of reducing this as it is a pain when plugging in backing tracks into the Aux from theiPad. Cheers Quote Link to comment Share on other sites More sharing options...
courteous Posted March 12, 2014 Share Posted March 12, 2014 Second that. I also get "the hiss" even with Master dial relatively low. Quote Link to comment Share on other sites More sharing options...
timthompson Posted March 12, 2014 Share Posted March 12, 2014 Are you using a noise gate in the chain? If not put in the noise gate and adjust the threshhold starting at 0 going up until the noise is gone. Also check your input and see if your setting for the second source is set on same. If it is, change it to Variax and the noise will dissapear. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted March 12, 2014 Share Posted March 12, 2014 There's a noise gate in the settings as well as a boost. It's at the top of the list. Quote Link to comment Share on other sites More sharing options...
