cromano Posted August 13, 2019 Share Posted August 13, 2019 How do you change the range on the expression pedal from 0 to 100% to something like 10 to 90% for full travel? I use to be able to do this on my GT-10 but I don't see any options in the Heliz. Very useful for volume and some wah's Please don't tell me to limit the travel of the expression pedal by my foot. That is not repeatable. Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 13, 2019 Share Posted August 13, 2019 You can't change the travel of the expression pedal, in the sense that it's only active over a certain range of the sweep. You can, however, adjust the min and max for whatever parameter(s) it's controlling. The min and max settings show up in the Controller Assign screen on the hardware. In HX Edit, you just go to the Controller/Bypass Assign tab and select the parameter you want to adjust and set the min and max values there. Quote Link to comment Share on other sites More sharing options...
