themetallikid Posted August 16, 2019 Share Posted August 16, 2019 So with the new amps etc...I'm deciding to redo my core tones/templates and 'clean house' from all the edits i've made to presets.... I went through my IR's chose my faves and got them imported into the IR list in HX Edit. Sat down today and started working on my Single Amp and Dual Amp Templates. For simplicity sake, I dropped the REVV A&C block in each template and got them leveled volume wise (using the merge block to compensate for the signal split, amp at stock settings). I then started working on the core tones, based off the template for Single Amp. I dropped a JC120 Amp only block in there at the end of Path 1, then dropped an IR on the first spot of path 2. Sounded like junk....tried swapping IR's, no difference in sound other than some change due to different speaker/mix choices. I'm using Ownhammer Freidman IR's....I started with the V30 (various mixes), tried different speakers.....no luck. They all sounded like either a room mic far away from the cab....or if you only heard a short reverb's wet sound and very little dry signal. I double checked my preset...no reverb block inserted...I checked to make sure I went to an Amp only block and didnt have a A&C plus an IR....everything was good there. I also noticed this when importing the 3 Sigma guitar IR's I just purchased as well. The presets I imported from before the 2.8(.1) upgrade were fine...but i'm worried now that those presets will be junk now that I've moved the IR's and am at where I'm at. I did notice that the IR's have a guitar pick symbol next to them...not sure where that came from or what it means. Any ideas why whats happenning is happening? Quote Link to comment Share on other sites More sharing options...
