HX Stomp midi bug
jency98
Hi I am a hx stomp user.
I found a problem while using hx stomp.
It sometimes hx stomp loses MIDI reception.
I use musicomlab EFX-LE as a MIDI controller.
6 blocks are turned on / off using MIDI cc #.
I will attach the error as a video. Blocks 3 and 5 are controlled using EFX. Sometimes the block doesn't turn off or turn on.
Block 1 = CC # 11
Block 2 = CC # 12
Block 3 = CC # 13
Block 4 = CC # 14
Block 5 = CC # 15
Did I do anything wrong?
When, in real life, would you rapidly switch between two effects continuously for 20 seconds?
My bet is that the problem is in the switches themselves, not being designed for such senseless abuse.
In fact, listening closely, I can HEAR the switches not fully activating when the "fail" occurs.
