cromano Posted August 29, 2019 Share Posted August 29, 2019 I have a Helix LT, about 2 years old and it see's no abuse. Recently the Ring LED's on all the foot switches do not come on. Nothing. The Exp 1+2 LED's come on and the display is working but all of the Ring LED's on the footswitches do not come on. This happens with the factory presets and my own. I did an update to the new firmware and still no LED's. The footswitches work and I can assign effects to them and I am able to bypass and turn on the effects by using the proper footswitch but No LED's on any and all footswitches will turn on. I've done the '3&4' Test mode check and tested the LED's and they don't light up. I tried the '2' LED light Fun and nothing happens, I'm guessing its supposed to light up like a christmass tree. I'm guessing a hardware issue but if anyone seen this and has a solution of suggestion please let me have it. I know I can use the display to show which effects are on which switch but the ring LED's are really nice and easy to see. Thanks Cromano Quote Link to comment Share on other sites More sharing options...
Peter Posted August 30, 2019 Share Posted August 30, 2019 I'm also guessing a hardware issue and would open a support ticket. ...You can try a reset(don't forget the backup), but I don't think it will help. ( Holding footswitch 9+10 on boot restores presets, setlists, globals and IRs (restores factory bundle) THIS WILL OVERWRITE ALL USER PRESETS AND SETLISTS ) Quote Link to comment Share on other sites More sharing options...
AugustoSeoane Posted July 11, 2023 Share Posted July 11, 2023 Did you solve the problem? My brand new Helix LT has the same problem.... Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 13, 2023 Share Posted July 13, 2023 On 7/10/2023 at 8:51 PM, AugustoSeoane said: My brand new Helix LT has the same problem.... Brand new should = warranty. I wouldn't try anything beyond a factory reset. Quote Link to comment Share on other sites More sharing options...
