Does Mission Engineering VM-Pro work with Helix Stomp
StanFur
Hello,
Just got the stomp. Wanted to check out the wah's on the unit and hooked up the VM-Pro from my main board to check it out but unable to get the Stomp to detect this volume pedal. Tried with TS and TRS cables (i don't have the Y cable) and have looked here and online to check if this pedal is compatible with the Stomp. I've spent the last day or so reading up and searching online but have not found anything related to the Stomp and the VM-Pro. Any info will be much appreciated. Thanks.
Another question: Will be getting the SP1-L6H - Can I use this as volume or wah but use an external foot switch as well (if I don't connect to the foot switch input on the SP1).
Thanks,
Stan
