Sign in to follow this
frankiebell
nono sends to stereo returns
I would like to send two mono returns to one stereo send, is that possible.
I need to have two effects sends from my console return to one stereo return on the console.
Is this possible. I am able to send one mono return to one stereo send but I would prefer having each mono return rout to one stereo send on the helix.
It is possible to insert two mono return blocks in the signal chain and one stereo send block.
You can mix the mono returns to one stereo send or you can use a separate path and stereo send for each one.
But I don't really understand, what you are trying to do. It only makes sence, if you use a some stereo effect block between the returns and sends.
I am trying to send two aux mono aux from my console and then return those to the stereo return on my console. I switched send and return 1 to line level
Sorry I don't quite follow. You want to connect 2 external effect pedals? - Why "send 1+2 in stereo and return 1+2 in mono"???
Can you explain, what you are trying to connect and why you need this "1+2 stereo/mono/aux" thing.
Why you don't use send1 and return1 for one effect and send2/return2 for the other effect?
want to return two mono signals to one stereo send
two mono aux from console back to one stereo to the console. I want to use the Helix as a effects unit for my console.
Use the return 1 input for one mono signal and the return 2 for the other mono signal.
Insert return block 2 after return block 1(mix 50%) and you have a mixed signal
Or you can use a splitted path (return 1 block in path 1A and return 2 in path 1B, for example) Then you can add a mix block, stereo effects and the stereo send 1+2 block.
Peter thanks, this is what I tried. I have two mono FX sends on my mixing board. I want to return those with different FX to the stereo return on my board. What this shows is two mono returns from the board, and one stereo send to the return on the board. Is theoritically right?UNADJUSTEDNONRAW_thumb_52d.thumb.jpg.16c74f66aebb6daa50096ebe59251ac8.jpg
