jameswilder
Spider V 240 stuck in FX menu
I recently purchased the spider V 240. If I press the FX button and turn any of the knobs, the amp button or home buttons do not respond. I have to turn the amp off and back on to get it back to the "home" menu. What am I missing?
  • Thanks 1
I had the same issue. Support sent me this and it solved the problem:
Please do exactly this: First install the older version of firmware, the one before 2.0, then once finished performer a factory reset on the amp. Once you've done this update to 2.0 again and the issue should disappear. Let me know how you make out afterwards.
  • Thanks 1
Had this problem with an older V120, was on first firmware, did not work when I updated 1.02 to 2.0.
Then I did all the firmware updates 1.03 than factory reset,  1.04 than factory reset,  1.05 than factory reset,  2.0 than factory reset, now it works like charm.
Good luck.
