HX Effects patching puzzle
Bananagab
Hi I just got the HX Effects and I love it but, I'm trying to do something that I don't know if it can be done.
I'm trying to do
Guitar -> HX Effects -> Amp with FX Loops -> Loadbox -> HX Effects for IR -> FOH
I've been trying differents things for a couple of hours but I can't figure it out!
How about.....
Set up 4cm as normal, but instead of taking the HX 1/4" Out to the Amp FX Return, use a second HX FX Loop Send.
Hook up the Load Box between the Amp and Speaker.
Take the Line Out from the Load Box to the second HX FX Loop Return, put your IR Block between the second FX Loop Block and the Output Block, then take the HX 1/4" Out to a DI and on to FOH. The basic preset would look like the attached example.
Possible problems:
Load Box Line Out has baked in speaker sim with no defeat switch.
Cure - get a different Load Box.
Second Helix FX Loop adds too much noise.
Cure - noise gate before the Output Block.
Second Helix FX Loop adds noticeable latency.
Cure - you're screwed.
I don't have a Load Box to test this with, and I'm assuming the HX FX works similarly to the HX Floor for the FX Loops.
Let me know if it works!
EDIT: Bad preset deleted. Good preset resent in follow up post.
Problem was I'd put a cab where the IR should go, forgetting that HXFX can use IRs but not cabs.
Your IR goes between the second FX Loop Block (FX Loop 2) and the Output Block. Make sure both FX Loops are ON.
Here is, as simple as I can make it, the wiring:
Guitar to HX Input
HX FX Loop 1 Send to Amp Input (set to Instrument Level)
Amp FX Loop Send to HX FX Loop 1 Return
FX Loop 2 Send to Amp FX Loop Return (set to Line Level)
Amp Speaker Out to Load Box Speaker In
Load Box Speaker Out to Speaker
Load Box LINE OUT to HX FX Loop 2 Return
HX 1/4" Out to DI to FOH/Board/Powered FRFR Speaker
If you're still not getting sound, give me the model info on the amp and load box and I'll try to figure out the problem.
4cm ldbx IR FOH.hlx
