Hx Stomp UseMIDI trigger Connection interrupred issue!
meizhuo
If you want to use ableton live to trigger MIDI to change the sound library.
Preferences >link MIDI >outport line6 hx stomp>track on and Sync on
Do not check input,  Sync.
 It will make  hx stomp "Connection interrupred"
In Hx stomp, select Golobal Settings>midi/tempo> Temop select >global
Hx tempo will follow your live.
Good luck!
Dunno about LIVE (live 10 Lite), I can't get it to record or play back to HX Stomp.
In Reaper, took two seconds to set up, works fine every time.
I'll have another look at LIVE later when I get back from errands.
On 10/4/2019 at 11:24 AM, meizhuo said:
We are talking about MIDI triggers
btw get 10 Suite It might solve you problem
Yes, that's what I'm talking about. Recording Audio is easy, but MIDI in Ableton is a problem.
I'm using LIVE 10 Lite because I have no real need for Ableton, and no way I'll spend real money on the suite when Reaper does more easier  than Ableton.
Unless you're into EDM and need the clip grid function, which I simply channel into Reaper using Rearoute when I need it.
If there's a trick to getting LIVE to record and playback MIDI, let me know. Attached is my LIVE MIDI Prefernces configuration.
Again, dunno about the "connection Interrupt" message, I'm not getting that.
Not only haven't I been able to record Program changes in LIVE (piece 0' cake in Reaper), but according to the LIVE manual, there's no way to do that, and the only way to send a Program change is at the beginning of a clip, by entering it manually.
Waiting to hear from meizhuo, who may know a trick......?
Midi control in live is easy but  hx edit "connection Interrupt"  I really want to know how to solve it.
(Do you need to trigger the hardware when the performance?Did you know that live can send midi signal change the sound library in the project.
If you want to control other hardware with MIDI function I can teach you in Live.)
Thank you for your reply.
Yes, that will send a PC at the beginning of a clip, but that's the only way I've found to do it. You can't record an extensive track with multiple Program Changes, and the manual method you've cited ONLY works at the BEGINNING of a clip. I searched the manual, and that's all I found. You know of another way?
