Denis347 Posted January 21, 2014 Share Posted January 21, 2014 Hi, I have been using my POD HD 300 for over 2 years now. Yesterday when I started my POD, there was no sound coming out of the device. I tried MP3 Input and it worked, I could hear the sound, but when I try to play the guitar, it seems that it is not getting any signal from guitar input (because the tuner doesn't work as well). I also tried sound from my computer through USB input, but no luck there as well. Factory reset, reinstalling firmware, reinstalling driver, non of these things seem to help. To summarize: no guitar input, no guitar output (obviously), no USB output, MP3 output works. I really don't know what might happen. Thanks for all help and suggestions. Quote Link to comment Share on other sites More sharing options...
Denis347 Posted January 22, 2014 Author Share Posted January 22, 2014 up (don't know if that's allowed here, but I need help with this issue :( ) Quote Link to comment Share on other sites More sharing options...
Cakickck Posted February 12, 2016 Share Posted February 12, 2016 I have the same problem with my hd300,please help Quote Link to comment Share on other sites More sharing options...
andhyguitar Posted September 19, 2016 Share Posted September 19, 2016 Hey, did someone solved this issue? My pod is with the same problem, only the mp3 output works Quote Link to comment Share on other sites More sharing options...
BillBee Posted September 20, 2016 Share Posted September 20, 2016 Try the guitar and cables on an amp minus the HD if everything works then it is the Pod. 1st thing to try is reflashing the firmware and pedal calibration. Still bad "maybe try a new power supply" borrow one or see if you can take it into a store to try theirs. Those are the obvious things and if they don't help it probably will have to go in for service. 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted September 20, 2016 Share Posted September 20, 2016 Let me preface this by saying I don't know if the POD will output anything without detecting some kind of input but if it will, try creating a patch in which you would hear alot of hiss (high gain amp cranked with a distortion box cranked) and has no noise gate. If you hear the hiss, it would indicate the issue is with the guitar input itself malfunctioning. Quote Link to comment Share on other sites More sharing options...
BillBee Posted September 20, 2016 Share Posted September 20, 2016 I don't know if the input section is anything like the X3 Live but when mine died (no input/or output) the mp3 player still worked. The tuner for the X3L is the first thing in the signal chain and that did not pickup a guitar signal so I know the inputs were dead. I don't have an HD300 but double check the input settings and like B said make sure the volume is up. Quote Link to comment Share on other sites More sharing options...
yasuke Posted March 19, 2017 Share Posted March 19, 2017 Did someone can solve. I just get problem :( My Pod HD 300 no input and some time get in put but not full signal. I already test the cable with another effect it is OK Please solve :*( Quote Link to comment Share on other sites More sharing options...
BillBee Posted March 20, 2017 Share Posted March 20, 2017 If you are getting a signal sometimes and you know the amp/cables/guitar are good then you might have a bad input jack. If you wiggle the cable in the jack and the sound starts/stops it might just need replacing or resoldering. Quote Link to comment Share on other sites More sharing options...
LloydN83 Posted August 9, 2017 Share Posted August 9, 2017 Hi I know OP might have sold his HD by now. HD300 user here.. But for others who's been having this issue just unplug, press and hold save button while plugging in, toggle the drive knob which will give you input choices (guitar, usb left, usb right) keep it on guitar, unplug and plug again... Solved! I almost cried when this happened and thought my beloved HD300 have died on me, and I couldnt afford a replacement as of now... Hope this helps some poor sap like my self! Keep on playing! 1 1 1 Quote Link to comment Share on other sites More sharing options...
zisnarf_miranda Posted August 23, 2017 Share Posted August 23, 2017 Hi I know OP might have sold his HD by now. HD300 user here.. But for others who's been having this issue just unplug, press and hold save button while plugging in, toggle the drive knob which will give you input choices (guitar, usb left, usb right) keep it on guitar, unplug and plug again... Solved! I almost cried when this happened and thought my beloved HD300 have died on me, and I couldnt afford a replacement as of now... Hope this helps some poor sap like my self! It worked! I almost lost hope with my unit! THANK YOU!!!!! Quote Link to comment Share on other sites More sharing options...
male_fah Posted September 4, 2017 Share Posted September 4, 2017 hi ... I also experienced the same thing, I've tried to change the cable, updating the driver, but still the same, it seems the engine is slow to keep the guitar sound for a few minutes, but 10 minutes later the situation returns to normal. this happens every new machine is enabled (POD HD300) Quote Link to comment Share on other sites More sharing options...
bjnette Posted September 4, 2017 Share Posted September 4, 2017 Check the input jack for a fault, loose connection. unplug from power, press and hold SAVE button while plugging in, toggle the DRIVE knob which will give you input choices (guitar, usb left, usb right) keep it on GUITAR, unplug and plug again. Check the input jack for a fault, loose connection. Re try the RESET of HD300 Save your patches first http://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214 Quote Link to comment Share on other sites More sharing options...
revilindo Posted February 11, 2018 Share Posted February 11, 2018 Check the input jack for a fault, loose connection.unplug from power, press and hold SAVE button while plugging in, toggle the DRIVE knob which will give you input choices (guitar, usb left, usb right) keep it on GUITAR, unplug and plug again.Check the input jack for a fault, loose connection.Re try the RESET of HD300 Save your patches firsthttp://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214 I've tried this and still wont work Any other ways Please help is it just software issue or hardware issue Quote Link to comment Share on other sites More sharing options...
SIRA72 Posted April 1, 2019 Share Posted April 1, 2019 On 8/10/2017 at 3:47 AM, LloydN83 said: Hi I know OP might have sold his HD by now. HD300 user here.. But for others who's been having this issue just unplug, press and hold save button while plugging in, toggle the drive knob which will give you input choices (guitar, usb left, usb right) keep it on guitar, unplug and plug again... Solved! I almost cried when this happened and thought my beloved HD300 have died on me, and I couldnt afford a replacement as of now... Hope this helps some poor sap like my self! Keep on playing! Fortunately for the others who posted replies their pods don’t appear to have had the same issue... Looks like this might be the fix.... mine is now working this morning, will try again tonight... I was wondering what the other figures in the display might be ? Sort of looks like a live data feed on the position of the dials.... Quote Link to comment Share on other sites More sharing options...
SIRA72 Posted April 2, 2019 Share Posted April 2, 2019 Ok, so that didn’t work.... interesting to know about though.... Seems to need 5 minutes to warm up whilst it gradually outputs more and more sound more and more clearly with the clipping and distortion reducing also.... Can anyone help? Quote Link to comment Share on other sites More sharing options...
neemoraes Posted May 22, 2021 Share Posted May 22, 2021 Olá a todos . E aí? Alguém conseguiu resolver o problema?? Quote Link to comment Share on other sites More sharing options...
ozzysky Posted June 25, 2022 Share Posted June 25, 2022 On 9/4/2017 at 4:51 PM, bjnette said: Check the input jack for a fault, loose connection. unplug from power, press and hold SAVE button while plugging in, toggle the DRIVE knob which will give you input choices (guitar, usb left, usb right) keep it on GUITAR, unplug and plug again. Check the input jack for a fault, loose connection. Re try the RESET of HD300 Save your patches first http://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214 Have tried all of these suggestions but still doesn't work out.. not a single note comes out. I'm suspecting the input itself is faulty. My POD was not power up for almost a year.. and this happens.. :( Quote Link to comment Share on other sites More sharing options...
pezvolador79 Posted October 11, 2022 Share Posted October 11, 2022 Hello, I'd like to give some insight about this matter. I've tried to unplug, press "save" while pluging back / choosing guitar instead of USB. It doesn´t work for me, but once you are in that mode, if you move the treble knob it allows you to choose the "z setting". It looks like the z setting has something to do with impedance. As soon as I choose a different value (can't remember now what exactly) the problem is solved. BUT: once I unplug and restart the pod the change in the z setting is lost and stops working again. I'ts curious that if I connect a booster pedal (a real one) before the pod it kinda works... not very well though I'm returning this unit and not buying any hd pod 300 or whatever ever more. Just wanted to give you my two cents. Cheers! Quote Link to comment Share on other sites More sharing options...
redstrat984 Posted February 29 Share Posted February 29 On 10/11/2022 at 8:07 PM, pezvolador79 said: Hello, I'd like to give some insight about this matter. I've tried to unplug, press "save" while pluging back / choosing guitar instead of USB. It doesn´t work for me, but once you are in that mode, if you move the treble knob it allows you to choose the "z setting". It looks like the z setting has something to do with impedance. As soon as I choose a different value (can't remember now what exactly) the problem is solved. BUT: once I unplug and restart the pod the change in the z setting is lost and stops working again. I'ts curious that if I connect a booster pedal (a real one) before the pod it kinda works... not very well though I'm returning this unit and not buying any hd pod 300 or whatever ever more. Just wanted to give you my two cents. Cheers! replace D31 and all came back ok magicaly :) it's a bat54s causing problem. Quote Link to comment Share on other sites More sharing options...
