Relay G10 transmitter broken connector?
pilot43t
I was plugging the transmitter into my bass at a gig the other night when I heard a pop like the plastic broke. The transmitter worked fine but I switched to a cable just in case. The plug now wiggles if I hold the base and move the plug. There are no apparent cracks. Should I worry about this or just roll the dice and hope that it wont get worse?
Well, that certainly sounds like something is broken inside the transmitter. There shouldn't be any play between the plug and the transmitter body. I imagine if you keep using it, it will only be a matter of time before it becomes worse. I'd suggest opening up a support ticket.
