Variax to front of house controlling sequences in Helix
I saw this old vid of usage of the Variax into the HD500 in the way I would like to use my Helix.
What is the routing sequence in the Helix to get these same changes.
Here is the video I saw that shows what I want to do but not how to program it.
Thanks Chris
https://youtu.be/1jjUkPlHdhg
  • 1 month later...
You do need to be a little more specific and it's been awhile since I've touched my HD500 but you essentially assign your JTV Variax's magnetic pickups to one input and the JTV Variax's modeling to another, he assigned an acoustic model. You then assign your volume pedal to adjust the outputs of each path. One path you make the Expression pedal toe down 0 and toe up 100 and the other vica versa. Expression pedal toe down 100, toe up 0.l
