ShoreProductions Posted November 19, 2019 Share Posted November 19, 2019 Installing Gearbox for POD X3 on OS X 10.12.6 Sierra This process works with the POD X3, I cannot confirm that it will work with any other POD of any other operating system other than OS X 10.12.6, Sierra, although it may. Download: Gearbox 3.72 for OS X from Line 6 Downloads: Select: All Hardware | GearBox | All OS - 1. Run the Line Monkey 1.78 App and insure that your software is up to date, particularly “Flash Memory 2.00” 2. Perform a typical install of Gearbox 3.7.2 3. Navigate to /System/Library/Extensions and remove, rename or relocate the “Line6Audio.kext” file. 4. Replace it with the "Line6AudioSigned.kext" file (Linked Below), or extract the file yourself from the Drivers 7.6.8 download. Select: POD X3 | All Software | All OS - Line6AudioSigned.kext.zip Please share your results, so others might benefit from your experience. Quote Link to comment Share on other sites More sharing options...
euie68 Posted August 18 Share Posted August 18 Replaced it but got an error message saying the replacement .kext file can't be used because it was installed incorrectly. Had to return the original .kext file from the trash! Quote Link to comment Share on other sites More sharing options...
