tootooh247 Posted November 28, 2019 Share Posted November 28, 2019 I heard about Helix floor can use Hardware / ui test Mode by hold FS4 & FS5 but for HX STOMP / EFFECTS / RACK its can access Hardware test or not ? thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 28, 2019 Share Posted November 28, 2019 6 hours ago, tootooh247 said: I heard about Helix floor can use Hardware / ui test Mode by hold FS4 & FS5 but for HX STOMP / EFFECTS / RACK its can access Hardware test or not ? thanks Hi, Not sure where you got the info about FS4 & 5, but it is wrong - that is not a valid combination. If you meant FS3 & 4 “Test Mode” that is only available on the Floor and LT models. For your entertainment here is the complete list of Reset/Test options for all the HX hardware from the website - https://helixhelp.com/ Helix Floor/LT Button Combination Description 2 LED light Fun 3 & 4 Test Mode 5 & 6 Global reset 7 & 8 Reset setlists to factory, Keep IRs 8 & 9 Reset setlists to factory, Clear IRs 9 & 10 Reset setlists to factory, Global reset, Clear IRs 10 & 11 Upgrades existing presets to latest format 11 & 12 Clear current preset 5 & 12 Clear setlists, clear IRs, Return system settings to default 6 & 12 Safe boot mode To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination Please note:Buttons are numbered from top left to bottom right. Helix Rack Since the rack doesn’t have footswitches, you’ll instead hold down a combination of the 6 encoders that are below the main LCD screen as you’re booting up. Button Combination Description ENC2 & ENC3 Reset globals ENC3 & ENC4 Restore stock presets and setlists ENC4 & ENC5 Restore stock presets, setlists, and IRs ENC5 & ENC6 Reset globals and restore presets, setlists, and IRs (entire factory restore) ENC1 & ENC3 Rebuild all presets ENC1 & ENC5 Clear all presets, setlists, and IRs ENC1 & ENC6 Will enter Update Mode (This feature is only available on firmware v1.06.5 and higher) HX Effects Button Combination Description Holding FS3 + MODE Will clear all Presets and IRs Holding FS4+FS5 Will reset Global Settings Holding FS5+FS6 Will reset Presets only Holding FS6+TAP Will Perform factory restore (reset, Globals, IRs, and Presets) Holding the right arrow ">" Will put the unit in a fail safe update mode. Use this when the HX Effects is in an un-recoverable state HX Stomp Button Combination Description All 3 Footswitches Clears all presets/IRs FS1+2 Resets presets and IRs FS 2+3 Factory restore (globals, presets, IRs) Have fun! 1 Quote Link to comment Share on other sites More sharing options...
tootooh247 Posted November 29, 2019 Author Share Posted November 29, 2019 Thanks ! 1 Quote Link to comment Share on other sites More sharing options...
jwoertz Posted July 19, 2022 Share Posted July 19, 2022 There are also test modes for each device. Any idea what the foot switch test mode is for the HX Stomp XL? Quote Link to comment Share on other sites More sharing options...
