Pod 2.0 stuttering / glitching
I have an 18 year old Pod 2.0 that recently developed a stutter - the audio cuts in and out rapidly. Not sure if it’s an issue with input or output but my guess would be that it’s an A/D conversion problem. Anyone else ever run into this and resolved it?
i know there are newer and shinier things out there (and I would use my Sonic Port with my phone or iPad, if it worked with iOS 13) but it would be nice to have this working again. Being able to just plug in and play has a lot going for it.
I recommend you test both of the audio cables and the USB cable. Swap them or replace them with known good cables. Also, do a full reset of the Pod 2.0, but make sure you've backed up your setting before you do or you will lose them.
