Pod HD500X settings with Power Amp of Katana MK2
merglet
Hey folks!
I just got a Katana MK2 100 Combo, which has a power amp in so the 4 cable method is no longer required.  I haven't tested it yet, but any advice on whether I should set the 1/4" out on the Pod to "Line" or "Amp"?  I'm thinking "Line" because "Amp" was for plugging into the front of an amp, correct?
Correct!
Power amps need LINE level signals.
FYI the 4CM (which would need a complete FX LOOP circuit with SEND and RETURN connections in the amp) is needed only to use both the pre-amp and power-amp of a real amp, and at the same time have maximum flexibilty to place the FXs before or after the pre-amp.
When connecting a modeler/multi-fx directly to the power-amp it means that you always bypass the pre-amp of your real amp (real amp gain and eq controls shouldn't affect the signal anymore), therefore you can replace it with one of the several pre-amp models available in the modeler. In regard to the FXs placement flexibility it is the same as with the 4CM.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Thanks hurghanico!  I know I could have experimented without bothering people, but I prefer to engage with people.  I used the 4CM before with a first-gen Katana 2x12, and it sounded great, and in a live situation it would be more appropriate (no unplugging cables).  But since I don't play live, this is far easier.  Appreciate the tip!
