HX Stomp expression pedal use: wah & volume
discartist
I connected a Moog EP-3, which I already had around, using a TS cable and got it to work with a volume pedal block.
I set the switch on the EP-3 to "Other" and inverted the polarity in HX settings. It comes up as EXP2 and works great.
Problem is when using it with a wah block, the expression pedal does nothing... You can see the value change on the HX, but the sound doesn't change.
Any ideas what's going on here? I'm cool with getting a Mission pedal, but hoping I can get this working.
Cheers
