barriecree Posted March 21, 2020 Share Posted March 21, 2020 I’ve just bought a new HX Stomp and an FRFR powered monitor for live use with a variety of basses. I usually feed our FoH mix direct with a, pre eq signal, from my amp via XLR but the little Stomp doesn’t have one of these. I wondered hat the easiest way might be to send a fully effected signal to my monitor but a relatively clean one into the FoH desk? Ideally I’d be looking for the least number of cables and connections. I guess I could send the same signal to both sources and reset the desk to accept an effected signal with amp and cab emulation etc. Any advice gratefully received :) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 22, 2020 Share Posted March 22, 2020 In Global Settings>Ins/Outs set Volume Controls to Headphones. This gives a constant UNITY output on the 1/4" Outs. Use MONO Effects only. Send one of the 1/4"" Outs to your FRFR and the other to FOH. Control your FRFR Volume from the FRFR, or put a small mixer or something between the Stomp and FRFR. You could also use a Send Block, but that wastes a Block. Quote Link to comment Share on other sites More sharing options...
barriecree Posted March 22, 2020 Author Share Posted March 22, 2020 17 hours ago, rd2rk said: In Global Settings>Ins/Outs set Volume Controls to Headphones. This gives a constant UNITY output on the 1/4" Outs. Use MONO Effects only. Send one of the 1/4"" Outs to your FRFR and the other to FOH. Control your FRFR Volume from the FRFR, or put a small mixer or something between the Stomp and FRFR. You could also use a Send Block, but that wastes a Block. Thanks for this. I have just played with the send blocks and I can see that I can send a clean, unaffected, signal to the Send out. Might try that for the FoH desk too. For most small venues I'm only the mix to add a bit of overall balance to the mix so it's not the core sound. I love how easy it is to do all of this in the Editor - genuinely intuitive! Quote Link to comment Share on other sites More sharing options...
