Can't install model pack on HD500X
amgradmd
Hi all. I bought the Fully Loaded HD model pack and cannot see the listed packs under license manager. I can see them listed under my computer but not the HD500X. I have deauthorized both and reauthorized them several times now. Used different USB cables and ports but the packs will not list under the HD500X to install in license manager. It's incredibly frustrating!! I have no reason to use them on my computer since I don't have POD Farm. ALL drivers/software/firmware is up to date. Can you only install them under either the computer OR the POD?? If so, how can I transfer? BTW, the POD otherwise works flawlessly and connects to and works with POD HD500X Edit perfectly well. Thanks in advance for your help!!
Adam
First advice: stop repeatedly authorizing and deauthorizing your stuff because there is a limited number of times you can do it, after which you'll have to ask the Line6 staff if they can give you further permissions to do it again..
Second: The License Manager is not the best program made by Line6, and it happens that even if the model packs are actually already installed/authorized in the device, you don't see them listed between the device add ons in the License Manager..
In order to see if the model packs are actually installed/authorized in your device the best and reliable method is directly on the device: press and hold the VIEW button to access the system settings and go to the last page, over there you will see listed what you have installed in your device, if you see your model packs listed nothing else to do is necessary.
PS. The HD model packs have nothing to do with POD FARM
All about POD HD500/X
help and useful tips
I have all the HD model packs (bought separately in different times, not the bundle) plus the model packs for the XTL and POD Farm.
In the following pic you can see what I see in the License manager in regard to my computer: just the XTL and POD Farm model packs, and POD Farm
and here what I see in regard to my HD500:
you can see that the POD is authorized but the add ons are not listed at all, but I have them all in my devices and I use them without any issue.
Are you able to see and select the amps in the model packs despite the fact that they don't show up in a listing? Scroll through the list of available amps on the HD500. Can you see the ones in the various model packs?
.... I have no reason to use them on my computer since I don't have POD Farm. ...
After more careful analysis/reasoning , the above reported sentences gave me a suspicion:
isn't it that you bought the model packs for the previous generation of the POD instead of the ones dedicated to the HD series?
Because in this case it would be impossible to authorize them in the POD HD.
1 hour ago, amgradmd said:
Yeah I have the same screen.
If you have exactly the same screen I have, especially the first one I posted, those model packs are not for the POD HD family.
That's totally it!! Ugh. I just assumed they all worked since I saw the POD HD500X available in the HD series model packs. I need to pay attention to the details. I guess I'll be asking Line 6 for a refund. Thanks so much!
