Lewis207 Posted April 20, 2020 Share Posted April 20, 2020 Hello - I’m hoping someone can answer my question. I recently bought a pod XT on eBay - it worked for 2 days and since then shows a blank screen when turned on. I gather that the best thing to do is “reflash” but after downloading drivers and updating firmware, I’m unable to update flash memory. Is there a fix for this or should I return the pod? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted April 21, 2020 Share Posted April 21, 2020 Go to this link from Line6 and follow the instructions. Quote Link to comment Share on other sites More sharing options...
Tinyfireball Posted April 22, 2020 Share Posted April 22, 2020 Hi will have to open the processor .there are 4 screws at the back. inside there is a flesh in the panel it must be removed carefully wiped with alcohol or cleaned with a rubber band from a pencil so that the contacts glisten and insert it back should work . this happens in XT and XT live from oxidation . Quote Link to comment Share on other sites More sharing options...
Lewis207 Posted April 24, 2020 Author Share Posted April 24, 2020 Great thank you! The first suggestion did not change the status but I will attempt steps the clean the interior part Quote Link to comment Share on other sites More sharing options...
decibelrebel Posted May 1, 2020 Share Posted May 1, 2020 "Hi will have to open the processor .there are 4 screws at the back. inside there is a flesh in the panel it must be removed carefully wiped with alcohol or cleaned with a rubber band from a pencil so that the contacts glisten and insert it back should work . this happens in XT and XT live from oxidation ." Will this work for a Pod HD? My screen is all black pixels - but if i hold it at different angles I can kind of see the correct screen under those black pixels....If so, can this be explained a little more clearly, i dont understand. What exactly is "a flesh in the panel" and where exactly is that? What is a rubber band pencil? Im not sure if these are electronic terms or typos.... thank you Quote Link to comment Share on other sites More sharing options...
