aKevBot Posted April 29, 2020 Share Posted April 29, 2020 Hi guys, Got an HX stomp a little bit ago and I've been getting into more modern metalcore recently so I've been checking out some video tutorials and whatnot to learn how to dial in a good sound (I'm more used to playing hard rock like Muse etc so the desired tones are quite different) Had some success recently in getting a decent amp sound using the Badonk with an 808, but now I'm looking to accomplish this sort of lo-fi effect you hear a lot in metalcore: I thought the megaphone would be ideal but it seems more tailored to vocals so it adds a lot of distortion as well, which sounds godawful with my amp. I tried to replicate the effect as in the video, but even using the high/low shelf EQ I was only able to reduce the highs and lows to -12dB, which kind of gets the desired effect but nowhere near as severely, if that makes sense. I guess I'm looking for a way to 100% cut out all the frequencies above and below a certain pitch, just wondering if there's a way to do this in Helix that I'm missing... All the EQ blocks seem to offer either a simple cut at a specified frequency, or not enough of a reduction in volume. I did try searching for other info on this topic but most of the threads I was finding were just referring to EQ cuts on the cab to fit a room better etc. and not this deliberate effect. Cheers! Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 29, 2020 Share Posted April 29, 2020 You could automate the HP/LP of the cab or IR to narrow the frequency band on a snapshot, or use a multiband EQ and pull down all the bands except for the middle ones. Quote Link to comment Share on other sites More sharing options...
aKevBot Posted April 30, 2020 Author Share Posted April 30, 2020 Thanks! The HP/LP on the cab worked great, just gonna see if I can assign it to an expression pedal to get that swell effect. Keeping my FX blocks to a minimum too which is great for the Stomp. Quote Link to comment Share on other sites More sharing options...
