Using a Helix with a preamp pedal:
showmpiano
Lets say I want to use an external preamp stompbox for some cleans. Would it be possible to put it through the loop of the Helix and add some reverb from that and then send it to a PA through the Out of the Helix, or do I need an amp block in the Helix? Can I set it up as a preset on the Helix?
Yes you can do that. You don't need an amp block in the Helix. Yes you can create and save a Helix preset for this. To do only this the preset would include nothing but the FX Loop. Of course you could add further Helix processing blocks if you wish.
Excellent! Thank you.
