innovine Posted February 5, 2014 Share Posted February 5, 2014 I'm having a bit of trouble with my DT25 A week or two ago it was working fine, and I changed a few of the preamps and cabs on it using DT Edit. Yesterday I started D Edit up again, and at first I got some popup error in DT Edit about not connecting, and an option to choose my midi device. I ran the program several times and got this each time, but after a while it stopped occuring. Now the program starts with no popup, but displays "Not connected" in the menu bar. The thing is, if I turn knobs on the amp, the changes are displayed on the screen, so _something_ is connected.. I've been using this midi interface for years and think its pretty good. I notice also that Monkey is not detecting my DT25 firmware version via midi either. Any ideas? Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted February 5, 2014 Share Posted February 5, 2014 The only thing that comes to mind is that the editor may not be able to send MIDI requests and get a response (he may send but the DT does not get it), but the DT sends out MIDI if you turn the knobs. Maybe a DT reset is in order if you have not already tried it. Quote Link to comment Share on other sites More sharing options...
chrishlp Posted February 9, 2014 Share Posted February 9, 2014 Hi, had the same happen to me with my HD500 and had to reload the latest firmware. Seems OK not, not sure what is going on but suggests problem with Monkey. Quote Link to comment Share on other sites More sharing options...
innovine Posted February 10, 2014 Author Share Posted February 10, 2014 After a bit of testing with a midi monitor, it turns out that the midi OUT side of the cable had an intermittent failure. So just wiggling it around a bit would get it to work, or fail. Glad I didn't update the firmware over that.. Quote Link to comment Share on other sites More sharing options...
