Pod Go works with USB-C ?
insidethegrave
Hi all,
Just bought a Pod Go a few a
hours ago online, waiting for the unit to arrive next week. In the meantime something stuck in my head for the last few hours. My computer is a Macbook 2019. I was thinking on editing and using the Pod God connected to my computer, but as you all might know, all the ports are Thunderbolt 3 (accept USB-C).
Does anyone knows if I can connect the Pod Go to my computer using a USB-B to USB-C cable ? or any other workaround to make it work over USB-C ?
I have a 2018 macbook Pro...Same deal...Works fine with the USB-C to USB-B, HDMI, USB-C adapter I have...I don't have B to C cable and don't know about those...I know they are out there and I imagine that they should work.
Hello,
USB-C is a connector specification.  Not a protocol.
Thunderbolt 3 connections  support up to USB 3.1 as well as the Thunderbolt 3 protocol.
And 100w bus power and other cool stuff.
It uses the USB-C type connector. This is a good thing.
One connector type to rule them all.
Some laptops will use USB-C for just USB devices.  Not Thunderbolt.
Most likely USB 3.0 or greater since USB-C came out after USB 3.0.
But the specification is backwards compatible for 2.0.
You just need the the right USB-C adapter cable.
