kurat Posted June 7, 2020 Share Posted June 7, 2020 Hi there, I just purchased an Ipad Pro 2018, which is my first Apple products for decades; come from Windows and Android OS. Then I purchased a Sonic Port VX, I plug in from Micro-USB/USB cable with an USB-C adapter. The device is detected by Mobile Pod, I can play guitar with it BUT it does not unlock the amp, if I want to access to full amps , cabs and effects, I need to purchase the app. Do you have any solution ? is it because I don t use the 14 pin to Lightning cable ? On windows with my UX2 or POD HD 500, I just have to run Line6 Monkey, should I need to register the device on line ? Any help is welcome thank you Quote Link to comment Share on other sites More sharing options...
renevanhezewijk Posted June 27, 2020 Share Posted June 27, 2020 I have more or less the same problem. The guitar --> Port VX --> iPad Pro+ POD --> Amplifier connection does not work (iPad Pro uses a USB C input), but guitar --> Port VX --> iPhone + POD --> Amplifier connection does work (iPhone with the original Lightning input). What I think is that the lightning cable coming from the Port VX when it goes into the iPad using an adapter (lightning female to USB c) there is a problem with the adapter. I bought Ringke adapters but I guess that's the problem. Let me know. Quote Link to comment Share on other sites More sharing options...
kurat Posted July 12, 2020 Author Share Posted July 12, 2020 Indeed, just change my old smatphone to an Iphone. Same as you. Guitar - > Sonic Port VX - > Iphone , with Lightning Line 6 cable, Mobile Pod is fully unlock, got sound and can play with the app or Bias FX Guitar -> Sonic Port VX - > Ipad Pro, with USB C cable, Mobile Pod just allow 4 amps The Lightning adapter to USB C seems only to work for charging, not audio or data transfer. I have send an Email to Line 6 Support, still no answer, I guess tthey may need a firmware updtate to allow to unlock the amp on the Ipad Pro, anyone from Line 6 can answer ? Quote Link to comment Share on other sites More sharing options...
guitarno Posted November 3, 2020 Share Posted November 3, 2020 @renevanhezewijk @kurat Did either of you get an answer on this? I am considering the Sonic Port VX or some other IOS interface for an iPad Pro (2018 version) and need to know if I will have this issue. Quote Link to comment Share on other sites More sharing options...
kmeals9898 Posted November 26, 2020 Share Posted November 26, 2020 Don't even waste your time on the Sonic Port XV. I just got mine out after it being packed away for a year and they still haven't fixed anything and gotten it working right. I just did sign in to see if there's a slime chance of news but.....nothing. I'm certainly not buying anything Line6 anymore. 1 Quote Link to comment Share on other sites More sharing options...
