jjjtriplet Posted June 9, 2020 Share Posted June 9, 2020 Has anybody else experience a glitch going from snapshot to snapshot. It happens every time when I go from 1/4 delay to 1/8 delay. Same preset just a change in a parameter setting. Delay and reverb Models the same. I tried trails on and trails off. Frustrating to say the least. It seems to me that you can’t have radical changes from snapshot to snapshot. Any help? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 9, 2020 Share Posted June 9, 2020 If you have very different settings from one snapshot to another, you may get some audio artifacts. With the delays, you can eliminate the chirping that happens when you change delay times by going to Global Settings>Preferences>Tempo Pitch and setting it to Transparent instead of Authentic. Quote Link to comment Share on other sites More sharing options...
jjjtriplet Posted June 11, 2020 Author Share Posted June 11, 2020 On 6/9/2020 at 1:31 PM, jjjtriplet said: Has anybody else experience a glitch going from snapshot to snapshot. It happens every time when I go from 1/4 delay to 1/8 delay. Same preset just a change in a parameter setting. Delay and reverb Models the same. I tried trails on and trails off. Frustrating to say the least. It seems to me that you can’t have radical changes from snapshot to snapshot. Any help? Quote Link to comment Share on other sites More sharing options...
jjjtriplet Posted June 11, 2020 Author Share Posted June 11, 2020 Ok Phil I will try that. Thanks for the info. Also does anyone know what preset I can build for swells and big swells. Not with a lot grit though. I found on you tube. Persons name is Alex. And gives an example on using 3 delays and one reverb. But he doesn’t show you the specifics of editing a preset in the Pod Go. His sound was awesome. Good worship feel. Quote Link to comment Share on other sites More sharing options...
