connollymusic Posted June 20, 2020 Share Posted June 20, 2020 I've got a signal going into my DAW (Mixcraft 6) directly from the PODXT Live. The problem is that it's extrememly loud in the headphones and the latency is terrible. How can I get a good signal into the DAW and control the volume in the headphones (with normal response or latency)? Thanks! Quote Link to comment Share on other sites More sharing options...
GitDD Posted June 21, 2020 Share Posted June 21, 2020 Are your drivers the most current? Is your system optimized? Is it to spec for what you want to do? Watch this; Quote Link to comment Share on other sites More sharing options...
daveny5 Posted June 21, 2020 Share Posted June 21, 2020 What audio interface are you using? You probably need to lower the buffer size to 128 samples or lower to eliminate the latency. Quote Link to comment Share on other sites More sharing options...
GitDD Posted June 22, 2020 Share Posted June 22, 2020 22 hours ago, daveny5 said: What audio interface are you using? You probably need to lower the buffer size to 128 samples or lower to eliminate the latency. He did mention Mixcraft as the software. I just assumed he was using the PODXT direct to it as the 'audio interface' as it does get detected as a sound device by windows. You can have playback and even Windows sounds can come through your guitar setup with the PODXT as the sound device. I was wondering if that may be the problem since there may not be an actual audio card interface or usb audio interface. I've never tried running my XT Live directly to a DAW as the actual interface or using Gearbox as a plug-in type setup so I'm not familiar with how it shows up in a DAW or what config options are available with it as the audio device. Quote Link to comment Share on other sites More sharing options...
daveny5 Posted June 27, 2020 Share Posted June 27, 2020 Are you using the ASIO drivers? Quote Link to comment Share on other sites More sharing options...
Dmirwi2m Posted January 21, 2021 Share Posted January 21, 2021 Quick simple fix. Adjust the output of the pod or adjust the external monitoring in your recording program. In my program Reason 9 there is actually a latency correction tool. Quote Link to comment Share on other sites More sharing options...
