Just purchased a used spider 4 150 watt head with the 4x12 cabinet. The sound only works through headphone jack. No sound at all when hooked through the left and right speaker outputs. Any help would be appreciated.
1) Either there's a problem with the jack as it cuts off the speakers when the headphones
or connection to recorder input is plugged in.
2) The power amp output IC's are damaged which also affects the speaker mute for headphone/recorder mode.
Either way , it will need to be serviced by a line 6 authorized service center. It is not a self repair situation.
