bryanriggs424 Posted July 11, 2020 Share Posted July 11, 2020 Hi there, just upgraded to the helix, which convinced me to upgrade to the powercab 212. Here is the issue- when I use the powercab output option (with any of the IR cab options, not in flat mode) within any helix configuration, as soon as I switch to that configuration, there will be a really loud burst of volume for a split second before it recognizes the settings and plays out at the desired volume. I haven't found any info on these threads, though I doubt I'm the only one with this issue. Maybe there's something in the settings I need to tweak? Any help on the matter would be much appreciated. Thanks! helix issue.mp3 Quote Link to comment Share on other sites More sharing options...
bobwohler Posted December 2, 2020 Share Posted December 2, 2020 I have the a Helix with a PowerCab 212 as well. The only similar thing I've run into is when I'm using snapshots with a preset, when I switch to that preset it can generate a burst of volume then settle down like you described. I've solved it for the most part by saving the preset with the snapshot I want but the volume level down to 0. I no longer get that burst but you have to obviously be aware that your volume is off. I suspect this would also happen if using just straight presets without snapshots and could also be solved by saving the preset with the volume down. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Wondo100 Posted December 17, 2020 Share Posted December 17, 2020 I am new to the 212 and have not experienced this yet. Yet being the operative word here. How, do I avoid this? Quote Link to comment Share on other sites More sharing options...
bryanriggs424 Posted December 17, 2020 Author Share Posted December 17, 2020 5 minutes ago, Wondo100 said: I am new to the 212 and have not experienced this yet. Yet being the operative word here. How, do I avoid this? play through a helix, and this happens when I choose the Powercab output through a custom helix configuration. For example, use one of the amp models available in the helix presets without a cab, then pick one of the 212 cabs for the output. Quote Link to comment Share on other sites More sharing options...
Wondo100 Posted December 17, 2020 Share Posted December 17, 2020 Oh, okay. That would make sense, I think in that you have to adjust levels to go from one to the other. I think I noticed that happening, but once you get everything programmed for a specific preset, going back and forth should not show up. Quote Link to comment Share on other sites More sharing options...
Maria987 Posted January 13 Share Posted January 13 This issue usually happens because of a slight delay in digital communication between your Helix and Powercab. When you switch presets, the Helix sends a command via the L6 Link cable to change the speaker model. For a tiny fraction of a second, CooMeet, the Powercab defaults to its "Flat" or maximum volume setting before the new instructions arrive. This brief gap creates that annoying loud burst of sound. It is a known quirk in how the two units talk to each other during the handshake process. To fix this, try adjusting your Global Settings on the Helix. Ensure your L6 Link Volume is balanced with your main output. Some users find success by setting the Powercab to a specific "User Preset" rather than letting the Helix block define every parameter instantly. You can also try lowering the channel volume on your Helix patches and raising the physical volume on the Powercab to minimize the impact of the jump. Quote Link to comment Share on other sites More sharing options...
