How to avoid accidental switch to signal flow view?
andyshieh
Greetings. New Helix LT user here. I've been very happy and amazed at all the features it has. It is such a game changer and will be my end-all-be-all guitar pedal.
One issue I've been having is that I've noticed my Helix accidentally switched from "Performance View" to "Signal Flow View" quite a lot.
I don't know exactly what triggered it to switch. It usually happened when I'm stomping on some of the switches to trigger effects on and off. But I've never touched the Signal Flow View button in these accidents.
It's kind of a problem when I'm in the middle of a song as it seems like the quickest way to go back to the performance view is to click on the little "Home" button twice, which is very hard to do with my foot.
Does anyone know any potential fix for this? Is there a particular button combination which I may have accidentally hit to trigger the switch from performance view to signal flow view?
If yes is there a way to disable that button combination?
Apology if the description of the question is a bit ambiguous. I'm still trying to pin down what exactly I did to cause the view switch, but I couldn't really find out, yet.
Turning off the "touch" feature should solve this. I turn it on only when I really need it (long day of editing), otherwise I find the screen heads off into unpredictable views, often at the worst time.
Global Settings > Footswitches
Touch Select
Set to "off"
