Samleyde Posted August 20, 2020 Share Posted August 20, 2020 When you use the looper, and want to delete what you've looped, you have to hold down the switch to delete but it plays 1 second of what you looped while it deletes. Does anyone know if there's a way to turn that off? I use the Pod Go for live solo acoustic gigs and it's super annoying. Quote Link to comment Share on other sites More sharing options...
cristt Posted August 21, 2020 Share Posted August 21, 2020 I have a delay/looper that has the same sort of bug, so I guess it's a design thing, when there's multiple functions assign to the same switch. As a workaround you could shut off your volume pedal while you are deleting the loop, then get it back to toe position. If turns out that it's a bug you may submit a support ticket to line 6. Quote Link to comment Share on other sites More sharing options...
