HX stomp with external tap + volume pedal
Samdbl
10 hours ago, Samdbl said:
a volume pedal in the middle of the chain
In fact, to save a valuable block slot, you can assign any other block's Level parameter to your expression pedal to serve as a volume pedal instead. Including the Main Output level which is always active.
And if you don't use a parallel path in your chain, you can have a "blockless" volume pedal in the middle by creating a "fake" parallel path for just the first block(s), route all signal to it and assign the Level parameter of the Mixer "miniblock" to your pedal.
