Diablo1 Posted September 2, 2020 Share Posted September 2, 2020 Can I get the Marshall Plexi sound and the superlead sound and is there a modded pkexi sound on the go Quote Link to comment Share on other sites More sharing options...
voxman55 Posted September 2, 2020 Share Posted September 2, 2020 Yes - In the manual there is a list of all the amp models and FX options. There are 9 Marshall options (and 2 'Park' that were an offshoot of Marshall). If you opt for the Jumped Plexi model it uses up about 42% of your DSP, so depending on what FX you might want to add, you might experience some limitations depending on how DSP hungry your selected effects use - but if you use pre-amp rather than amp ( parameters not quite as wide) you can save on your DSP . See here (under 'PG' column) to see how much DSP each model uses: https://benvesco.com/store/helix-dsp-allocations/ Quote Link to comment Share on other sites More sharing options...
