roknrev Posted February 13, 2014 Share Posted February 13, 2014 after several minutes of operation m9 becomes static. the only fix is a restart. this inconvenient! sometimes when in neutral (no signal going in) there is obviously fm interference. help! Quote Link to comment Share on other sites More sharing options...
Muskratt Posted February 17, 2014 Share Posted February 17, 2014 Might try to check that your cables are not crossed over power supplies and other things that can introduce a signal. Do a close inspection of your power supply cord to and at the relief at the pack. I would say to get a can of DeOxit to clean all your cables and inputs too. Spray it on the 1/4" male connector and insert and remove it 4-5 times to each jack. Do this on your amp as well and the FX loop if you have even if you don't use it. Never spay in the jack as you may short the gear out if it doesn't completly dry. BE SURE YOUR AMP IAND GEAR S POWERED OFF if all else maybe a reflashing the firmware may help. Quote Link to comment Share on other sites More sharing options...
