Philby2809 Posted September 15, 2020 Share Posted September 15, 2020 I got a Boss EV-30 expression pedal today and I'm trying to set it up with my HX Stomp. I'd like to do the following: in Snapshot 1, I want to use the exp. pedal to control the delay parameters (heel - short delay, toe - long delay). In Snapshot 2, I want to control the rotary speed, without affecting the delay settings. Is that possible? Thanks in advance, Marko Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 15, 2020 Share Posted September 15, 2020 If you have the delay turned off in the snapshot where you want to control the rotary, then, yes, you could use the same pedal to control both. The pedal will still be controlling the delay parameters, but since the delay is turned off, it won’t matter. Quote Link to comment Share on other sites More sharing options...
Philby2809 Posted September 15, 2020 Author Share Posted September 15, 2020 Ah, I see - so the expression pedal can't be set up to have different parameters assigned in different Snapshots? Thanks for clearing that up! Quote Link to comment Share on other sites More sharing options...
