Blending 2 IR's on HX Stomp
Falcor77
Nothing to do. The Split block splits the main stereo signal into two stereo signals. The Mixer block mixes the two stereo paths back into one stereo path. Since IRs are Mono, the two stereo paths are now one mix of two Mono paths, but post Mixer is still stereo until you add another Mono block. If you add a stereo block post mixer, you've got stereo. Control the level of IR1 vs IR2 either at the IR blocks or at the Mixer block. Control the placement in the stereo field at the Mixer block.
23 minutes ago, Falcor77 said:
Thanks! So if I want to blend them together say 30% then I would pan left 30 and right 30 at the mixer block?
"Panning" refers to the position of a signal in a stereo field. Blending is the opposite. If you'll be running a stereo signal (ending in separate right and left speakers) you would use panning. If you want MORE of one signal than the other in the final mix (mono OR stereo) then use the Level controls, either at the cab/IR block, or at the mixer.
But if I want them to blend, don't I need a mono block after the mixer block so they sum together?
