Lkgean66 Posted November 9, 2020 Share Posted November 9, 2020 Just wondering if someone has had a problem with no distortion on dirty channels while using the 4 Cable Method. Really frustrating... is it the amp? or is it improper routing ? Something in the Global settings? 4 CM routing confirmed and re-checked. Using Meas Boogie MkV, channel switching working fine with TRS cable. We tried putting one cable into the front of the amp and it works fine, sent ins and outs from HX Effects through FX loop in MkV and worked fine, but in 4CM, after channel switching, channels 2 and 3 have no distortion and Master volumes within the channels are disabled. Making arrangements to get the head into the shop but I figured I'd try on this forum. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 9, 2020 Share Posted November 9, 2020 7 hours ago, Lkgean66 said: Just wondering if someone has had a problem with no distortion on dirty channels while using the 4 Cable Method. Really frustrating... is it the amp? or is it improper routing ? Something in the Global settings? 4 CM routing confirmed and re-checked. Using Meas Boogie MkV, channel switching working fine with TRS cable. We tried putting one cable into the front of the amp and it works fine, sent ins and outs from HX Effects through FX loop in MkV and worked fine, but in 4CM, after channel switching, channels 2 and 3 have no distortion and Master volumes within the channels are disabled. Making arrangements to get the head into the shop but I figured I'd try on this forum. Do you have the FX Loop block in your HX Effects preset? Quote Link to comment Share on other sites More sharing options...
Lkgean66 Posted November 9, 2020 Author Share Posted November 9, 2020 Yes, I believe so.... path A. Should there be a path B? Just want to confirm. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 9, 2020 Share Posted November 9, 2020 30 minutes ago, Lkgean66 said: Yes, I believe so.... path A. Should there be a path B? Just want to confirm. You don’t need Path B for the 4CM, no. You just need the FX Loop block in the chain. Anything before the loop will be before your amp, and anything after the FX Loop will be in your amp’s effects loop. Quote Link to comment Share on other sites More sharing options...
Lkgean66 Posted November 9, 2020 Author Share Posted November 9, 2020 So yeah, all that is in play but still no distortion on channels 2 and 3. Quote Link to comment Share on other sites More sharing options...
