External expression pedal not working with Go
boynigel
Trying to use my Ernie Ball expression pedal to (in this case) control the mix value of a delay. I do the assignment procedure as per the manual but it doesn’t work. If I move the pedal through it’s range I can see the values change as to how I set them, but the pedal turns into a volume pedal in the process...meaning heal-down outputs NO sound. Adding to the strangeness the on board volume pedal no longer functions.
