Feedback when using HX Stomp as an audio interface
akabek
I am trying to record a guitar track using the HX Stomp as a user interface into a PC using Reaper.  When I arm the track I get a lot of feedback and the effect results in a very high frequency.  I do not have any issues using the Stomp with any of the presents into my monitors.  I have a feeling the signal going into the DAW needs to be lowered.  I also tried running the Stomp in my Scarlett 2i2 but the same thing happens.  How do I correct this?  I checked the global setting but I do not see where I can lower the signal strength.
If you have your monitors plugged into your Stomp when you’re recording, there shouldn’t be any difference compared to when you’re just playing through it. It sounds like you may have direct monitoring turned on in Reaper - the armed track would be processing audio through Reaper and then sending it back to the Stomp. If that’s the case, you’d want to turn that off. With ASIO devices you don’t need direct monitoring through the DAW, as you’re monitoring from the source itself.
